Тема: Hecterra Release Notes
Hecterra v5.1.0
Apr 19, 2022
In this application version, a new type of report is available. It shows information about the progress of work in all the fields of a specific campaign.
Product Manager (Mobile)
Hecterra v5.1.0
Apr 19, 2022
Hecterra v1.0.1
June 11, 2019
- Now you can search fields not only by their name but also by their description. It may come useful if you store legal or other specific information in the fields’ descriptions.
- The calendar has become more convenient — now you can easily go through years with the help of the forward/backward buttons. This can be crucial when filling in crop rotation for fields.
- Now we ignore non-movement intervals at the beginning and at the end of a cultivation. It leads to a more accurate calculation of beginning/end time of a cultivation, which is especially important in cases when tractors stay on the fields overnight.
- The search of candidates has been optimized and now works quicker.
Hecterra v1.0.2
June 19, 2019
- A new report type has been added. It shows all cultivations for the selected period (regardless any particular unit, field, etc.).
- Now you can export your fields to a file of KMZ format. It allows storing the fields as well as transferring them into another resource or even system. Field’s external contours and inner “holes” are stored in the file.
- A limit of 1000 lines in an executed report has been introduced. It prevents your browser form overloading. If at some point you need a bigger report, please break up your request into smaller periods to avoid this limitation.
- Localization of maps has been improved and now depends on the language chosen in user’s settings.
- We have applied virtual scrolls in selects and combo boxes, which makes long lists work faster.
Hecterra v1.1.0
July 2, 2019
- API for compound cultivations (cultivation of a field made by several units and/or drivers and/or continuing for a number of days).
https://sdk.telepuls.ru/products/hecterr … ultivation
Hecterra v1.1.2
July 15, 2019
- A setting to indicate the start of the working day has appeared (helps with “shifts” as well as cultivations made overnight).
- In candidates and cultivations, we have added a field showing the time when this cultivation was found (important if you want to understand what data and algorithms were involved in finding this particular cultivation).
- A new flag for a crop has appeared — “Winter crop”.
- Brazilian Portuguese is now available.
Hecterra v1.1.3
July 18, 2019
- New dashboard with three-month calendar and activity markers.
- New type of report — By crop.
- Exporting report to CSV — now only the chosen columns.
Hecterra v1.1.4
July 29, 2019
- Compound cultivations (interface for combining single cultivations, detailed view of a compound cultivation, and compound cultivations in reports).
- Registering crop rotation (sowing/harvesting) when approving a cultivation.
Hecterra v1.1.8
Sept 17, 2019
- Fuel consumption by math (figures are taken from the Wialon report “Statistics”).
- If a report interval contains at least one part of a compound cultivation, we show such cultivation with all its parts.
- A warning to the user about the fact that one time-consuming request is already being processed for the resource (search of candidates, creation of a compound cultivation, or recalculation of a candidate). We don’t allow launching another such request until the first one is finished.
- Croatian language.
Hecterra v1.1.9
October 2, 2019
- Export of reports to .xlsx files (for MS Excel & similar).
Hecterra v1.2.0
Oct 10, 2019
- Work sensors: now cultivations can be detected with the help of the “work sensor” (this sensor indicates whether or nor the implement is actually operating). To activate this option, set the Work Sensor Name in the setting of Hecterra.
- Interface in Polish is now available.
Hecterra v1.2.1
Oct 21, 2019
- Now working width & operation for the implements in Hecterra can be taken from custom fields of the trailers in Wialon.
- New information about candidate/cultivation in the Developer Mode: working day start & version of the field.
- Increased limit of rows for reports: from 1000 to 5000 rows.
- Layout changes in the Settings.
Hecterra v1.2.2
Nov 11, 2019
- Control of speed violations during cultivation. Set speed limits in the operation and estimate the result when observing a cultivation on the map.
- Visualization of implement’s work during cultivation.
- Optimization of cultivation search.
- Ability to log in directly from WH, including as other user.
Hecterra v1.2.3
Nov 25, 2019
- Fullscreen mode to better observe cultivation on the map.
- Possibility to skip same-name fields when importing fields from a file (prevents the creation of unnecessary duplicates).
- Additional warning when deleting a field with cultivations (the exact number of cultivations to be deleted together with the field).
- Information about the work sensor (if used) in dev mode.
Hecterra v1.3.0
Dec 23, 2019
- New algorithm of area calculation has been introduced. Now all areas (i.e. calculated area, omissions, and especially overlaps) will be calculated much more precisely. You may try the new algorithm on new cultivations, or delete an already registered cultivation and then search it and register again. Warning: recalculated cultivations cannot be returned to their former state.
Hecterra v1.3.2
Jan 16, 2020
Filtration of fields by crop has been implemented:
- On the Fields page, now it is possible to observe only corn fields, or only potato fields, etc. The filtration applies to the list as well as to the map.
- The same filtration can be used while exporting fields to a file.
Hecterra v1.3.3
Jan 27, 2020
- On the Fields page, one can observe not only the actual number of fields but also their total area. The feature also works with filters by name, crop, etc.
- Upon the completion of import or synchronization, the map will automatically scale to show all fields.
- Fullscreen mode is now available on the Fields page.
Hecterra v1.3.4
Jan 31, 2020
- “Quick crop rotation”: now you can set current crop for a field in two clicks.
Hecterra v2.0.2
Mar 5, 2020
- Work shifts in reports. Shifts are configured in the Settings. Then they can be used as a filter in reports to show cultivations related to a particular work shift.
Hecterra v2.0.3
Mar 25, 2020
A new feature in the Synchronization: the option to merge geofences with already existing fields if their names and descriptions coincide. This feature can be useful when geofences are re-created in Wialon.
Hecterra v2.0.4
Apr 6, 2020
A new feature in reports: a common map for all cultivations in the report.
Hecterra v2.0.5
Apr 16, 2020
- Adjustable coefficient of mileage for detection of a cultivation — 80%, 60%, 40% from field’s perimeter.
- Option to turn on\off the names of fields on the map.
Hecterra v2.0.7
May 14, 2020
- Bulk operations for fields: delete several fields at once or select a crop for several fields in one go.
- New option for min mileage in relation to field perimeter — 20% (to find even smaller cultivations).
- Enhanced synchronization of trailers/implements: now custom fields with working width and operation may be drawn to Hecterra even in case of already existing implements (if their corresponding properties are empty).
- On the Registrar page, we added dates to Start and End cells (previously, there was only time).
Hecterra v2.1.0
June 11, 2020
- Backup (export/import) of resource data (fields, crops, crop rotation, operations, cultivations, etc.)
- WMS maps with time layers
Hecterra v2.1.1
June 18, 2020
- Area in ha has been added to the labels of fields on the map
Hecterra v2.1.2
June 25, 2020
- Enhancements in Dashboard
Hecterra v2.1.3
July 9, 2020
- Improvements to reports exported to Excel
Hecterra v2.1.4
July 14, 2020
- New option in resource settings — Cultivations at low speed — to find cultivations for machinery which moves at near-zero speed (like coffee harvesting machines).
- In selects, we added tooltips for long names.
Hecterra v2.1.5
July 28, 2020
- Cultivations with the asymmetrical placement of the implement
- Use the work sensor to calculate the start, end, and duration of a cultivation
Hecterra v2.1.6
Aug 6, 2020
- Fuel rates for cultivations in registration and reports
Hecterra v2.1.7
Aug 20, 2020
- Tools to measure distance and area on the map.
Hecterra v2.1.9
Sep 17, 2020
- Now the grouping of data can be applied in reports: by driver, operation, crop, field, or unit.
- ID of Wialon geofences has been added to API.
- New interface language — Czech.
Hecterra v2.2.0
Oct 1, 2020
- New ways to get fuel for cultivations: set priorities of fuel sensor types
Hecterra v2.2.2
Oct 20, 2020
- Improvements for reports exported to Excel (fonts enlarged, excessive text removed)
- Software calculation of the course (to provide the correct calculation of overlaps for units that do not send the course)
Hecterra v2.2.3
Nov 10, 2020
- New limits for time-consuming requests. Previously, only one time-consuming request was allowed per a resource at a time (search or recalculation of candidates, combining cultivations, etc.). Now many of these limits are applied to a session of a user (and not to the resource) — this allows simultaneous work of several operators within a resource. Herewith, it is not possible to manipulate the same unit or cultivation at the same time.
- New layout of the Settings page: separation of user settings from report settings.
Hecterra v2.2.4
Nov 19, 2020
- Autofill for fuel consumption rates when registering a cultivation
Hecterra v3.0.0
Dec 10, 2020
- U.S. measurement units (acres, feet, gallons, etc.) are now available in Hecterra. To set the alternative measurement system for your resource, go to Settings => Resource and choose “U.S.”
Hecterra v3.0.5
Jan 28, 2021
Recently, we have released a series of updates that improve your experience in Hecterra.
We have introduced new designs for:
- Cultivation page
- The selection of units on the registration page
- Approving and declining cultivations from the table of potential cultivations
- The selection of multiple drivers for a potential cultivation
- New layout of tabled reports
Hecterra v3.1.0
Feb 18, 2021
• Brand new functionality — consumables: now you can create lists of seeds, fertilizers, and chemicals, as well as indicate their consumption rates while registering a cultivation.
• Columns in reports became resizable.
• Now using right/left arrows you can easily flick through the dates in the calendar on the Registration page.
Hecterra v4.0.0
Apr 15, 2021
• Changes in crop rotation: now it’s possible to have several crops within one year, to set a crop for several years in a row, and to assign crop rotation using dates in future.
• The notion of ‘winter crop’ has been removed.
Hecterra v4.0.2
May 27, 2021
• The top menu has been updated: Crops, Operations, Implements, and Consumables became items within the Catalogues menu.
• Now when using the quick method to specify the current crop, it is possible to set sowing and harvesting dates manually.
• Translation into French.
Hecterra v4.1.0
Jun 10, 2021
• General table of Crop Rotation — all fields, all crops, all years on one page.
• Now labels of the neighbouring fields (name+area) can be shown when a field is being created or edited.
• Date format in crop rotation now depends on user settings.
Hecterra v4.1.1
Jun 24, 2021
• We introduced “What’s New” window. It pops up at the login and shows brief information about new features we release. You may close the window (and then it will reappear only with the next update) or you may go deeper and read more about new possibilities or discuss them in our forum.
• We developed a new setting to divide found candidates by work shifts — "Divide potential cultivations considering shifts". It helps to get the right intervals of work even if you don’t assign drivers in Wialon.
• We added the Update button to the Crop Rotation page so that you could quickly load the most recent changes.
Hecterra v4.1.2
Jul 1, 2021
• Now you can adjust the time for the tractor to make a turn outside the field — it can vary from 1 to 5 minutes. You may need this option to have fuel and mileage calculated more precisely.
Hecterra v5.0.0
Aug 17, 2021
New functionality — Campaigns. Create campaigns (e.g., Harvesting of wheat, Spraying of corn, etc.) to watch their progress and make further decisions.
More info
Hecterra v5.0.1
Sep 21, 2021
• You can now save the map with fields to a PNG file.
• The cultivation search settings now can be adjusted straight on the Registrar page. Those temporary settings will be applied during the current session.
• When a compound cultivation is created, now it will be shown straight away so that you can check it without going to reports.
• Sorting by any column has been added to the list of campaigns.
• A button to refresh campaign’s progress has been added.
• Sequence order of report types has been changed on the Reports page.
Hecterra v5.0.2
Oct 19, 2021
- You can now save the map with cultivations to a PNG file.
- Minor changes and bug fixes.
Hecterra v5.0.4
Nov 25, 2021
Now you can monitor the campaign progress directly on the Dashboard page. To add campaigns to the Dashboard, activate a special flag for them on the Campaigns page. You may add as many campaigns as you want.
Hecterra v5.0.7
Dec 28, 2021
• Now when you save a part of the map to a PNG file, the file name reflects its contents. For example, the file name with an image of a field includes the field name, the file name with an image of a cultivation includes the name of the field, unit, operation, and the date.
• We have also added the ability to apply the While Label option to the application logo. To order this service, contact your personal manager.
