Отправка некорректных данных на сервер после выключения питания.
Тема: Отправка некорректных данных на сервер после выключения питания.
Машина поло 2013 года
Если зажигание включено все данные приходят корректные- нет вопросов,
;ALT:134.0,adc0:0.0,adc1:0.0,adc2:0.0,adc3:0.0,engine_hours0:0.02,mileage0:94145.0,fuel_consumption0:0.0,fuel_volume0:42.0;in1:0,out1:0,,SATS:12,bat_voltage:194,call:0,c0:0,c1:0,c2:0,c3:0,odo_track:0,gsm_power:0,gprs_state:0,acc:0,sos:0,granit_alarm_info:0,engine_rpm0:1104,engine_temp0:62,speed0:0,axis_weight0_1:6540,axis_weight0_2:6540,axis_weight0_3:6540,axis_weight0_4:6540,axis_weight0_5:6540;;sec_flag_status0:1654784,alarm_flag0:0;;
;ALT:134.0,adc0:0.0,adc1:0.0,adc2:0.0,adc3:0.0,engine_hours0:0.07,mileage0:94145.0,fuel_consumption0:0.0,fuel_volume0:42.0;in1:0,out1:0,,SATS:12,bat_voltage:201,call:0,c0:0,c1:0,c2:0,c3:0,odo_track:0,gsm_power:0,gprs_state:0,acc:0,sos:0,granit_alarm_info:0,engine_rpm0:687,engine_temp0:73,speed0:0,axis_weight0_1:6540,axis_weight0_2:6540,axis_weight0_3:6540,axis_weight0_4:6540,axis_weight0_5:6540;;sec_flag_status0:1658880,alarm_flag0:0;;
но как только выключают зажигание
0,adc0:0.0,adc1:0.0,adc2:0.0,adc3:0.0,engine_hours0:42949671.69,mileage0:42949671.69,fuel_consumption0:4294967169.0,]fuel_level0:32641.0;in1:0,out1:0,,SATS:0,bat_voltage:203,call:0,c0:0,c1:0,c2:0,c3:0,odo_track:0,gsm_power:0,gprs_state:0,acc:0,sos:0,granit_alarm_info:0,engine_rpm0:65409,engine_temp0:-127,speed0:255,axis_weight0_1:6540,axis_weight0_2:6540,axis_weight0_3:6540,axis_weight0_4:6540,axis_weight0_5:6540;;sec_flag_status0:0,alarm_flag0:4294967169;;
ALT:162.0,adc0:0.0,adc1:0.0,adc2:0.0,adc3:0.0,engine_hours0:42949671.69,mileage0:42949671.69,fuel_consumption0:4294967169.0,fuel_level0:32641.0;in1:0,out1:0,,SATS:5,bat_voltage:203,call:0,c0:0,c1:0,c2:0,c3:0,odo_track:0,gsm_power:0,gprs_state:0,acc:0,sos:0,granit_alarm_info:0,engine_rpm0:65409,engine_temp0:-127,speed0:255,axis_weight0_1:6540,axis_weight0_2:6540,axis_weight0_3:6540,axis_weight0_4:6540,axis_weight0_5:6540;;sec_flag_status0:0,alarm_flag0:4294967169;;
.0,adc0:0.0,adc1:0.0,adc2:0.0,adc3:0.0,engine_hours0:42949671.69,mileage0:42949671.69,fuel_consumption0:4294967169.0,fuel_level0:32641.0;in1:0,out1:0,,SATS:9,bat_voltage:203,call:0,c0:0,c1:0,c2:0,c3:0,odo_track:35,gsm_power:0,gprs_state:0,acc:0,sos:0,granit_alarm_info:0,engine_rpm0:65409,engine_temp0:-127,speed0:255,axis_weight0_1:6540,axis_weight0_2:6540,axis_weight0_3:6540,axis_weight0_4:6540,axis_weight0_5:6540;;sec_flag_status0:0,alarm_flag0:4294967169;;
Re: Отправка некорректных данных на сервер после выключения питания.
Температура после выключения зажигания -127 )
Терминал Гранит с канлогом
Зажигание видим (подключен провод)
Как сделать так, чтобы если зажигание выключено , то данные не отображались, а то странности показывает...
login_sbl Делайте валидацию на неравенство нулю, допустим по датчику зажигания. И тогда невалидные данные не будут учитываться. Почитать тут https://docs.telepuls.ru/ru/hosting/cms/ … validation
Безопасность превыше всего
AN-Security Direct
