Ignition sensor on a DCT Syrus
Topic: Ignition sensor on a DCT Syrus
I am working with a dct syrus device. When I want to configure the engine ignition sensor, I have problems since I use the parameter “event” to indicate when the engine is on. The bad thing about this, is that in this parameter all the different events configured show up, like the panic button, the aggressive movement, engine on and off. So I can not configure this sensor correctly. Someone can help me or tell me what can I change in my script for Syrus device, so I can have the ignition parameter correctly.
(edited by jhdeguate 04/10/2017 14:51:57)
Re: Ignition sensor on a DCT Syrus
crvg19 in Wialon you have to use "in9" (input 9) as parameter to sense ignition,  In your script you have to use "F00" to send the ignition status on unit, as this:
>SED00NA0;F00+< # Ignition ON
>SED01NA0;F00-< # Ignition OFF
Regards,
Jary Hernandez
Thanks for your help, but still no luck.
Stil with the same problem. If you can check my script, cause we dont find where is the error.
Regards,
Carlos Valdez
Test
>SXAEFC;VO;IO<
