Long Road Geofence Notification
Тема: Long Road Geofence Notification
Hello,
Use case: To trigger a notification when a unit has entered or left a certain road.
What is the best method of implementing this? Creating a long geofence along the road does not work because it intersects many other different roads.
Thank you.
Re: Long Road Geofence Notification
Hello,
Please try to use: https://docs.telepuls.ru/en/hosting/user … er#address
Hello,
This will not work since it is a long road (highway/freeway). Someone mentioned that I could use position filter for the areas I want to exclude from the notification but that may require geozone overlays. How would I do this?
Hello,
levon пишет:
It is still not clear why creating a long line geofence won't suit you, and also why intersection whit other road will affect standard geofence control notification.
levon пишет:
Such filters can be applied in reports, but not in notifications. Notifications can control entering to or exit from list of geofences only.
@ Oleg Zharkovsky
