Update Service Interval using Javascript API.
(28/05/2019 02:25:34 отредактировано orlo_26)
Тема: Update Service Interval using Javascript API.
Hello everyone!
First, thanks for taking some time to read this topic.
Basically What I need is to Update a Service Interval using Javascript API. BUT there is not documentation about this... Has any of you tried to do this before?
I think that the method "updateServiceInterval" exists... But Im not sure how/what parameters send.
Example:
 var servs = unit.updateServiceInterval(params);
I tried to use the order you can see on the Remote API, but it is not working.
Remote API doc: https://sdk.telepuls.ru/wiki/en/local/re … e_interval
Even, if you have the documentation about how to do this on Javascript... It will be awesome!
Thanks in advice!
Re: Update Service Interval using Javascript API.
orlo_26
Fisrt of all you sould load th library "unitServiceIntervals",
sess=wialon.core.Session.getInstance();
sess.loadLibrary("unitServiceIntervals");
After that from a unit object you should have 2 new methods, createServiceInterval(params,callback) and updateServiceInterval(params,callback,action).
params and action should be as descibred in the link you posted.
