Hello !
The sensor data can be represented in many different report tables. It depends on sensor type.
The all sensors data can be get from report with table Sensor tracing
So first you need to create sush report template then can execute report via API. Please look example here
To get sensor's IDs - just use the request search_item( or search_items ) with flags = 4096
The JSON response will contain the list of units sensors with their IDs
To get registration plat number from profile fields - the same requests to search items, but with flags = 8388608
https://sdk.telepuls.ru/wiki/en/sidebar/ … ile_fields
You can sum all required flags to get all data at one JSON response, for example flag = 8392705 ( 8388608+1+4096 ) will return JSON with base data, sensors and profile fields.
