hhamedk wrote:Diana, are you sure? If we are talking about API and clients we are in discussion with your team that it should work like what you told or at least the user should have possibility to choose what should happen if the IP changed (terminating the session or keeping it alive) but your colleagues told me that is will keep session alive and no way to terminate it. (I guess you use cookies for that BTW)
Hi Hamed,
This requirement is described here in documentation
https://docs.telepuls.ru/en/hosting/req/ … connection
May be you mean that If user login to Wialon, using option 'Remember' , then if IP address was changed during the user's session, the current session will be interrupt, but Wialon will re-login user automatically again - with new session and new IP address.
But for any custom app, if there is not realized such mechanisms, or if user doesn't use option 'Remember' to Wialon , after IP changed, the current session will be just interrupt.
