Not possible to have all "Advanced properties" with core_search_items
Тема: Not possible to have all "Advanced properties" with core_search_items
Hi,
  Since today,  not possible to have all information of "Advanced properties", I have all the information, but not "Advanced properties" only two of them "act and "dactt", I need 'ph" for example.
  Yesterday, it was working, but today no, I don't think to modify something.
    "uid":<text>,    /* unique ID (hardware) */
    "uid2":<text>,    /* second unique ID (hardware) */
    "hw":<long>,    /* hardware type */
    "ph":<text>,    /* phone number */
    "ph2":<text>,    /* second phone number */
    "psw":<text>    /* password */
    "act":<bool>    /* unit deactivated - 0, activated - 1 */
    "dactt":<long>    /* deactivation time UNIX, 0 - unit is activated */
I use the same functions since the beginning,
def fct_InfoUnit(wialonAPI, unitName):
    global unit
    spec = {
        "itemsType": "avl_unit",
        "propName": "sys_name,rel_billing_account_name",
        "propValueMask": unitName,
        "sortType": "sys_billing_account_guid",
        "propType": "sys_name"
    interval = {"from": 0, "to": 0}
    try:
        unit = wialon_api.core_search_items(spec=spec, force=1,
                                            flags=0x3FFFFFFFFFFFFFFF,
                                            **interval)
        # print("Info-unit:")
        # print(unit)
    except WialonError as e:
        print(e)
and to have the token with this parameters :
// Main function
function getToken() {
    // construct login page URL
    var url = dns + "/login.html"; // your site DNS + "/login.html"
    url += "?client_id=" + "App";    // your application name
    url += "&access_type=" + 0xFFFFFFFF;    // access level, 0x100 = "Online tracking only"
    url += "&activation_time=" + 0;    // activation time, 0 = immediately; you can pass any UNIX time value
    url += "&duration=" + 604800;    // duration, 604800 = one week in seconds
    url += "&flags=" + 0x1;            // options, 0x1 = add username in response
    url += "&redirect_uri=" + dns + "/post_token.html"; // if login succeed - redirect to this page
Regards,
Pascal
Re: Not possible to have all "Advanced properties" with core_search_items
Hi Pascal,
It seems like user doesn't have the following access to unit - View connectivity settings (device type, UID, phone number...etc)
https://help.telepuls.ru/help/wialon-hos … cessRights
Please check it, may be somebody has changed access rights
