zant пишет:kpoiii92 здравствуйте, в запросе все специальные символы должны быть в кодировке URL-encode. В данном случае значение формата времени (time_format) необходимо кодировать в таком формате: %25E.%25m.%25Y_%25H%3A%25M%3A%25S
Пример выполняемого без ошибки запроса:
hst-api.telepuls.ru/wialon/ajax.html?svc=report/exec_report¶ms={"reportResourceId":22563712,"reportTemplateId":0,"reportObjectId":25118133,"reportObjectSecId":0,"interval":{"from":1684875600,"to":1684962000,"flags":0},"reportTemplate":{"tbl":[{"p":"{\"address_format\":\"1255211008_10_5\",\"time_format\":\"%25E.%25m.%25Y_%25H%3A%25M%3A%25S\",\"us_units\":0}","f":0,"filter_order":[],"s":"[\"address_format\",\"time_format\",\"us_units\"]","sl":"[\"Address\",\"Time Format\",\"Measure\"]","cp":"","cl":"","sch":{"fl":0,"w":0,"m":0,"y":0,"t2":0,"t1":0,"f2":0,"f1":0},"c":"","l":"Статистика","n":"unit_stats"},{"p":"","f":0,"filter_order":["base_eh_sensor","duration","mileage","engine_hours","speed","trips","stops","parkings","sensors","sensor_name","driver","trailer","fillings","thefts","geozones_ex"],"s":"","sl":"","cp":"[{},{},{},{},{},{},{},{}]","cl":"[\"Моточасы\",\"Холостой ход\",\"Пробег\",\"Ср. скорость\",\"Ср. расход\",\"Начало\",\"Конец\",\"Вес груза\"]","sch":{"fl":0,"w":0,"m":0,"y":0,"t2":0,"t1":0,"f2":0,"f1":0},"c":"[\"duration\",\"duration_stay\",\"mileage\",\"avg_speed\",\"avg_fuel_consumption_all\",\"time_begin\",\"time_end\",\"loading_avg_weight\"]","l":"Моточасы","n":"unit_engine_hours"}],"p":"{\"descr\":\"\",\"bind\":{\"avl_unit\":[]}}","ct":"avl_unit","n":"АМ_Моточасы","id":0}}&sid=ВАШ_SID
Спасибо помогло, не подскажете что здесь не так?
"reportResourceId": 22563712,
"reportTemplateId": 0,
"reportObjectId": 24721652,
"reportObjectSecId": 0,
"interval": {
"from": 1672921896,
"to": 1672952309,
"flags": 0
"reportTemplate": {
"tbl": [
"p": "",
"f": 0,
"filter_order": [],
"s": "[\"render_theft_markers\"]",
"sl": "[\"Маркеры сливов\"]",
"cp": "",
"cl": "",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "",
"l": "Сливы",
"n": "unit_thefts"
"p": "",
"f": 0,
"filter_order": [],
"s": "[\"render_filling_markers\"]",
"sl": "[\"Маркеры заправок\"]",
"cp": "",
"cl": "",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "",
"l": "Заправки",
"n": "unit_fillings"
"p": "",
"f": 0,
"filter_order": [],
"s": "[\"render_location_markers\"]",
"sl": "[\"Последнее местоположение\"]",
"cp": "",
"cl": "",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "",
"l": "Последние данные",
"n": "unit_location"
"p": "",
"f": 0,
"filter_order": [],
"s": "[\"render_msgs\",\"render_trips\"]",
"sl": "[\"Все сообщения на карте\",\"Треки поездок\"]",
"cp": "",
"cl": "",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "",
"l": "Поездки",
"n": "unit_trips"
"p": "{\"address_format\":\"1255211008_10_5\",\"time_format\":\"%25Y-%25m-%25E_%25H%3A%25M%3A%25S\",\"us_units\":0}",
"f": 0,
"filter_order": [],
"s": "[\"address_format\",\"time_format\",\"us_units\",\"precise_calculations\",\"exclude_thefts\",\"trips_mileage\"]",
"sl": "[\"Address\",\"Time Format\",\"Measure\",\"Пробег/Топливо/Счетчики с точностью до сотых\",\"Исключить сливы из расхода топлива\",\"Считать пробег только по поездкам\"]",
"cp": "",
"cl": "",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "",
"l": "Статистика",
"n": "unit_stats"
"p": "{\"grouping\":\"{\\\"type\\\":\\\"total\\\"}\",\"sensor_name\":\"Пробег ТС (газ),Расход (газ),Расход (ДТ)\"}",
"f": 0,
"filter_order": [
"duration",
"mileage",
"base_eh_sensor",
"engine_hours",
"speed",
"stops",
"sensors",
"sensor_name",
"driver",
"trailer",
"geozones_ex"
"s": "",
"sl": "",
"cp": "[{},{},{\"p\":\"(absolute_mileage_end) - (absolute_mileage_begin)\",\"m\":\"км\"},{\"p\":\"(counter_sensors)\",\"m\":\"км\"},{\"p\":\"(absolute_mileage_end) - (absolute_mileage_begin) - (counter_sensors)\",\"m\":\"км\"},{\"p\":\"(counter_sensors) * const100 / ((absolute_mileage_end) - (absolute_mileage_begin))\",\"m\":\"%\"},{},{\"p\":\"(fuel_consumption_imp)\",\"m\":\"м3\"},{},{},{}]",
"cl": "[\"Начало\",\"Конец\",\"Общий пробег\",\"Пробег в ГД\",\"Пробег в ДТ\",\"% пробега в ГД\",\"Потрачено ДТ\",\"Потрачено газа\",\"Потрачено\",\"Потрачено по ДУТ\",\"Счетчик\"]",
"sch": {
"fl": 0,
"w": 0,
"m": 0,
"y": 0,
"t2": 0,
"t1": 0,
"f2": 0,
"f1": 0
"c": "[\"time_begin\",\"time_end\",\"user_column\",\"user_column\",\"user_column\",\"user_column\",\"fuel_consumption_abs\",\"user_column\",\"fuel_consumption_all\",\"fuel_consumption_fls\",\"counter_sensors\"]",
"l": "Поездки",
"n": "unit_trips"
"p": "{\"bind\":{\"avl_unit\":[]},\"descr\":\"Администраторский расширенный отчет с графиками показаний газового оборудования\"}",
"ct": "avl_unit",
"n": "АМ_Сводка_Для_1С",
"id": 0
