JS API: Get Unit list
(20/10/2012 14:54:37 отредактировано unitedsecurity)
Тема: JS API: Get Unit list
hello developers, i have one request. i need very simple example for getting users unit list  from test wialon with javascript API. i dont know how manipulate with sid into js API. i read sdk documentations but i cant understand how i can make that. please help me smile thanks.
Великий и ужасный Гиоргий Каладзе
Re: JS API: Get Unit list
Hello. You can visit http://sdk.telepuls.ru and see examples for JS API.
Mobile Development
thanks for answer kopa but that examples for begining develope wialon is too difficult for me. in this documentation is all examples into one object.  i need code with get units not more. please wirte if you know smile
First you need to authorize to service. And then use searchItem(String/Number id, Integer dataFlags, callback?) or searchItems(Object searchSpec, Integer forceRefresh, Integer dataFlags, Integer indexFrom, Integer indexTo, callback?) function in Session object to get units. This is "Item: search" sample in the samples list. http://docs.gurtam.com/api/hosting/#wialon.core.Session
Mobile Development
thanks kopa for answer. i write that code :
var ss = mySession.searchItem(\"11691002670134\",0x00000001,function(code,item){
        if(code){
        wialon.core.Errors.getErrorText(code);
        } else{
        alert(item);
but its not correct. please fix my problem. i want alert search result. thanks.
searchItem(ItemId, wialon.item.Item.dataFlag.base, function(code, item){alert(item.getName());});
Mobile Development
var ItemId = '11691002670134';
mySession.searchItem(ItemId, wialon.item.Item.dataFlag.base, function(code, item){alert(item.getName());});
error:
Uncaught TypeError: Cannot call method 'getName' of null
This means an item with such itemId not exists.
id- GUID or ID of item to search for
I think you're using the hw id and it's not correct.
Mobile Development
// get available units
    // search parameters
    var searchSpec = {
      itemsType:"avl_unit",
      propName: "sys_name",
      propValueMask: "*",
      sortType: "sys_name"
    var dataFlags = wialon.item.Item.dataFlag.base|wialon.item.Item.dataFlag.image|wialon.item.Unit.dataFlag.restricted|wialon.item.Unit.dataFlag.lastMessage;
    wialon.core.Session.getInstance().searchItems(searchSpec, true, dataFlags, 0, 0, function(code, data) {
      if (code) {
        alert(wialon.core.Errors.getErrorText(code));
        return;
      // TODO:
Denis Strakh, Gurtam
If it avails you to have more practice, the Unit search example in the Wialon Java API is a good starting point. Just be sure to make sure your username and password are kitdemo and kitdemo
Here is the example: https://sdk.telepuls.ru/wiki/en/local/ja … les/search
hello,
I hope this example will useful for you.
https://sdk.telepuls.ru/playground/demo/get_units
Hello, I am facing a problem,
In login it needs "token" and "operateAs",
but, how can I get this?
farah.aidid пишет:
Hello!
First token it needs to get login with username and password manually via authorization page ( form )
Then you can use received any in login request. Please look here more information about token authorization
"operateAs" as optional parameter, it only needs to use if user login under histhelf, and then needs to login under another user
