Create command with remote API
Тема: Create command with remote API
Hi,
I am triyng to create a command but it is getting error: 4, I am looking for the error but I cant figure it out.
This is my url to create the command
https://kit-api.telepuls.ru/wialon/ajax.html?svc=unit/update_command_definition&params={"itemId":6897076,"id":0,"callMode":"create","n":"PedirUbicacion","c":"send_position","l":"","p":"","a":0xffffffffffffffff}&sid=42595eb1306f114468fc45772b21dfc3
Re: Create command with remote API
Hello, glizarraga
The issue is common for the cases either with connection timeout or with the syntaxis of the command (http://sdk.telepuls.ru/wiki/en/sidebar/r … ors/errors). If you specify the command itself we can figure out what is not going right.
Best regards.
