Using "upload Configuration" System in Wialon with Teltonika HW?
Тема: Using "upload Configuration" System in Wialon with Teltonika HW?
hi guys,
does anybody used this http://extapi.telepuls.ru/hw/cfg/teltoni … tcp_en.pdf already?
I tried but failed.
Wolf.
(i "developed" a config file, than i added a command in Wialon where i choosed the config file. no pass/user set in the fm1100. but seems that i have do to a bit more...)
Re: Using "upload Configuration" System in Wialon with Teltonika HW?
Wolf
I do not know if this will help but I was having a problem uploading to a Ruptela device and found that the issue was the link time out. Change the timeout to a larger value and the uploads started working.
For the Ruptel'a Wialon was always starting from the first packet if the connection was lost.
Regards
John
Phoenix Solusi
Mobile Visible Secure
Specialists in data acquisition and analysis for mobile and fixed assets. Integration in to content management systems is a specialty we have.
i already managed to send configurations via Wialon Hosting to a Teltonika HW.
Only the file you send must be done by yourself and is not so easy ;-)
Wolf.
Dear Wolf,
Could you please explain the process?? I have had issues with uploading config for Teltonika devices as well.
And the above mentioned .pdf guide is not understandable.
Thanks!
Dear Wolf,
we tried to send HW file to Teltonika according to manual but unfortunately not all settings were delivered. Could you please share any file as example?
Thank you!
Michal.
Enjoy :-))
ServerIP:193.193.165.165
ServerPort:20412
APN:internet.eplus.de
GPRSLogin:eplus
GPRSPassword:gprs
1,000,0
1,001,1
1,002,1
1,003,1
0,201,1
1,010,1
1,011,280
1,012,300
1,240,1
1,242,internet.eplus.de
1,243,eplus
1,244,gprs
1,245,193.193.165.165
1,246,20412
1,247,0
1,271,26203,26201,26202,26207
1,540,180
1,543,1
1,544,181
1,545,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF
1,550,60
1,551,0
1,552,0
1,553,1
1,554,60
1,555,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF,FF
1,300,1
1,301,1
1,302,0
1,303,0
1,304,2
1,305,333
