Тема: Eco Driving report template update
Hello,
For one of our clients , we need only one of several criterion in Eco Driving.
Would it be possible to make filter in report template Eco Driving for special criteria.
Thanks a lot.
Hello,
Thanks a lot.
That's easy.
If you need just one criterion, for example speeding, adjust this criterion in Unit Properties and don't add anything else.
We already have few criterion with speeding in Eco Driving.
Criterion that we need to use is Custom with sensor and validator.
It's specific criterion because we fallow speed in one region (oil refinery), there is to many big tanks and that is problem for position of device (HDOP is to big)
Also speedings in Advanced tab in Unit properties we already use with fixed value.
Thanks
monitoringnet, sorry. I don't think I understand you right.
Could you please explain in more detail your idea?
Alek
We follow speedings over 30 km/h in specific geofence.
That geofence is not on road, it's field beside.
Field is oil rafinery and there is many sheet metal tanks, because of that HDOP of device is in many situation big, and speed is not valid.
Picture below:
So what we need is to ignore speedings with big HDOP
My idea is to create custom Eco Driving criteria with custom digital sensor when speed is 30 km/h, sensor is on and custom digital sensor validator when HDOP is below 1 , sensor is on.
Just i said in post before because we have already 7 criteria in Eco Driving for other purpose and speedings in advanced tab is also used, for report that we need only criteria i describe above, filter would be good solution.
Info that we need in report is time when speeding starts,end,duration,max speed and driver
Thanks
Maybe, you simply need to create a report for visits to this particular geofence and indicate "Min speed" option (=30 km/h) and "Retrive intervals".
See our docs for details:
http://docs.telepuls.ru/en/hosting/user/ … /geofences
http://docs.telepuls.ru/en/hosting/user/ … filtration
Hey Alek,
I just want to thanks on advice.
i need to contact support on mail, because I had a vague and i need to give them user and pass of account.
In few days , i'm gonna test report, and if i need some more help , i'll contact you.
Thanks once again.
monitoringnet, that's OK, no problem.
If you need more information or some assistanse when testing this report, just write here in this forum.
May be better to use on device geozones and speed limits with a wait time before the speeding alert is activated so that the jumping due to high HDOP is filtered out. This however depends on the device you are using. We currently manage 4 speed limits using this method covering in tank terminal, built up areas and highway.
Hello JohnG what device do you use? Thanks
We are using the Ruptela Pro4 it does not full meet what we want to do but it is closer than most of the other devices.
ECO Driving
Sample of Road Fuel Tanker Movement Parameters for ECO Driving
