Тема: Remote API exec_report
Hi,
I am trying access exec_report through Remote API using the standard parameters at http://sdk.telepuls.ru/wiki/en/local/rem … xec_report & http://sdk.telepuls.ru/wiki/en/local/rem … es/reports
but I got {"error":4} while I followed all the steps through it using the PHP class and tried the java script url but I got the same error .. Known that I faced the same problem with core/search_items and obviously it happen when the function uses nested array because anything but this works fine
this an example of my code in PHP
$wialon_api->report_exec_report('{
"reportResourceId":512156,
"reportTemplateId":41,
"reportObjectId":931510,
"reportObjectSecId":0,
"interval":{
"from":1450501520,
"to":1450687920,
"flags":0x00
Could you please tell me where is the error and if there is ready online working example I can use to figure out my problem can I get it because all your examples with demo account didn't work
