How do I know if I am inside a geofence?
Topic: How do I know if I am inside a geofence?
Hello,
I have a question, for of "Remote API" I can find the position according to the values of altitude and length but, I would like to check or know the form with "Remote API" to know if my coordinates correspond to a geofence or if my position inside of a geofence.
Can I help you, please with this details?
Re: How do I know if I am inside a geofence?
Hello.
There is resource/get_zones_by_point method, in which you can pass some coordinates and set of resources with a list of zones, that will respond with filtered lists of zones which contains your point.
Hello, rual
Yes, thank you for this information but, this method I get an empty array. I put the position of geofence in the parameters "lat" and "lon"  but array is empty.
This is the request:
https://hst-api.telepuls.ru/wialon/ajax. … :{%220%22:[]},%22lat%22:20.578478,%22lon%22:-100.387650}}&sid=02e516527944c71a834c5f1514fbbc69
Can I help you, please? if the request is issue.
You could also try running a report template for geofences. But this is a little more complicated.
Not that solution to run a report is not recommend to use for what is being developed, thank you cerpas , The link with the Remote API is necesary but the array is empty, I don´t understand, if my request is correct.
Some suggest or idea please.
(edited by rual 23/06/2017 10:33:22)
Denisse wrote:
Hello, rual
You have had sent:
{"zoneId": {"0": []}, ... }
But actually you need to get list of resources, that contain geofences of your interest and send something like this:
{"zoneId": {"<resourceId1>": [], "<resourceId2>": [], ...}, ... }
// Also, do not post links with sid anywhere, because with that identifier everybody can login into your account (in short period of time, but anyway, it is insecure).
Oh rigth!
Yes, I change the request for "resourceID" is correct.
Thank you very much for this information and detail.
I found the below call easy to check out all the resources along with resource IDs that I have.
svc = core/search_items and params={
        "spec":{
            "itemsType":"avl_resource",
            "propName":"sys_name",
            "propType":"property",
                "propValueMask":"*",
            "sortType":"sys_name"
                "force":1,
              "flags":1,
              "from":0,
              "to":0
