WialonCRM - convenient work with objects and not only. wialoncrm.com
Topic: WialonCRM - convenient work with objects and not only. wialoncrm.com
Start working: https://wialoncrm.com
Dear friends!
We present  to you our new development for Wialon Hosting system - WialonCRM!
WialonCRM is:
+ Screenshot
  • convenient view of objects, accounts, users and messages.
  • convenient, fast and flexible data filtering.
  • convenient and flexible work with sensors.
  • Russian and English  languages localization support.
Filter
+ Screenshot
  • Powerful and flexible data filter
  • The ability to choose which columns to display
Messages
+ Screenshots
  • Output of the latest messages from the object directly on the main page.
  • Easy charting of any parameter or sensor.
  • "Live" table and graph - when new messages arrive, they are automatically added to the table, and the graph is build up.
Objects
+ Screenshot
  • Ability to change basic properties.
  • Instant check of ID and phone number for uniqueness with issuing a link to a duplicate object.
  • Viewing the last received message on the main page.
Flexible and powerful editor of sensors
+ Screenshot
  • Convenient addition and removal of sensors
  • It contains the whole functional of SensorCalc: just copy your calibration table from a text file, or drag the file itself into a text box!
  • A "live" graph that immediately responds to a table change.
  • Calibration tables  specific formats support (for specific sensors). Currently added support for  Italon sensor  format. New formats will be added in the future.
  • The values "output" of the sensor are displayed immediately as soon as the settings become correct (the input parameter is selected and, if necessary, the calibration table is set).
  • Ability to set value boundaries automatically.
  • For multi-fueltank machines - the ability to combine several sensors. The selected sensors become invisible and gets voluntary type, then a new sensor is created, witch adds up the values of the selected sensors.
  • WialonCRM - convenient work with objects and not only. wialoncrm.com
Андрей Чудин
Re: WialonCRM - convenient work with objects and not only. wialoncrm.com
chudin Very, very, very interesting...
Will be testing and giving you my feedback!
¡ Thanks a lot !
jhdeguate  with impatience we will wait for your feedback and suggestions
Андрей Чудин
(edited by chudin 06/10/2017 10:28:36)
Filtering data in WialonCRM
Dear friends! Today, we'll show you how to work with data filters in WialonCRM.
Overview
The filter panel is located at the top of the WialonCRM.
+ Screenshot
The filters panel contains the filter reset button, the text fields, the corresponding columns, the time interval selection button and the count selection ticks displayed on the page of the rows.
Filter by column
Filtering by column is very simple - you enter text in the appropriate text fields, the system quickly searches for what you need. In the screenshot, we filter the data by the column "Account" and "Name" and get only 4 records that match our requests.
+ Screenshot
Displaying Columns and Filtering
In the system, you can configure the display only those columns that you need. In this case, the text fields corresponding to the columns are added (or removed) in the filter panel. Display settings are saved only for the browser in which you are currently working.
In the screenshots, we are adding the columns "Parent Acc" and "Creator", and then we filter the data on the "Creator" column.
+ Screenshots
Output of data by time
The system allows you to filter out the data by time. To do this, click the "clock" button in the filter panel and select the gap in which you want to filter out, and set the sliders to be cut off. A system for filtering data within the framework of Hour, Day, Week, Month and Year .
In the screenshot, we filter out the data for the "Parent Acc" column with screening within the day in the range  from 16:21 to 16:43
+ Screenshot
In the future, we will publish notes, notes and video for working with WialonCRM .
Андрей Чудин
(edited by chudin 12/10/2017 21:48:04)
Dear friends!
WialonCRM now supports not only Wialon Hosting, but also Local!
When authorizing, select your version of Wialon, if it's Local, specify the address of your server (or address, if there are several).
+ Screenshot
Андрей Чудин
Dear friends! We have added the ability to copy sensors inside the object.
Also we work on the function of copying sensors between objects (without uploading files).
+ Screenshot
Андрей Чудин
Dear friends! We have prepared a small, but useful update WialonCRM! Cloning sensors between objects is ready!
We implemented it as part of a more general cloning function for the properties of the object, which will appear in the future.
+ show spoiler
Андрей Чудин
what is different between cms.telepuls.ru and https://wialoncrm.com?  What is the main purpose of https://wialoncrm.com
What are the requirements if i require a branded version of CRM?
When i click the location hyperlink, its redirecting me to a map with language which is not the one selected on the user profile. Is there a possibility of changing the default map language?
(edited by chudin 04/12/2017 12:00:39)
1) Branding WialonCRM will be available only in the full version.
2) We replaced Yandex Maps with Google Maps. The Google Maps service will determine the interface language and maps.
Андрей Чудин
Hello.
Today we are releasing an update WialonCRM - module WialonCRM Plus.
  - Full functionality of work with objects, users and accounts.
  - Functionality of working with groups.
Андрей Чудин
Hello!
We released a small but useful update in the WialonCRM Plus module: moving objects from one account to another.
What happens when you move objects:
1) It is checked whether the object is connected, new and old accounts are connected to WialonCRM;
2) It is checked whether the new account allows you to add new objects. If necessary, limits and services are adjusted to ensure the possibility of transfer;
3) It sets the full access for the user-creator of the new account to the transferred object;
4) Object is transferred;
5) For the user-creator of the new account, access to the object by the selected template is established;
6) The user-creator of the old account is denied access to the transferred object;
7) If the object is in the main group of the old account, then the object from it is deleted;
8) The object is added to the main group of the new account (the group is created if it is not already created).
+ show spoiler
Done! All these actions are automatic. Less clicks - more results;)
Андрей Чудин
thanks you
Lps Trackers
