Тема: Active directory or SSO login integration
Is it possible to login with customer SSO or Active directory with his platform
Does the Wialon Local system support this?
No, unfortunately it's not possible.
Login into Wialon should be done with token which received only (at least one time) via authorization form - https://sdk.telepuls.ru/wiki/en/local/re … ogin/login
Thanks for your support and fast reply.
