Тема: Batch work for every unit in the system through low level API call
How can I do batch work for every unit in the system?
I'm trying to build the query string like this in Julia - code is very similar to python -
function batch_events(plates; week=43, year=2023)
sid = ssid()
monday = Dates.firstdayofweek(Week(week) + Date(Year(year)))
sunday = Dates.lastdayofweek(Week(week) + Date(Year(year)))
start = datetime2unix(monday |> DateTime) |> Int32
stop = datetime2unix(sunday |> DateTime) |> Int32
detectors = [
Dict(:type => "trips", :filter1 => 0)
items2load = []
for plate in plates
push!(items2load,
Dict(:svc => "events/load",
:params => Dict(
:ivalType => 1,
:itemId => plates2ids[plate], # I have a map from plates to your internal IDs
:timeFrom => start,
:timeTo => stop,
:detectors => detectors
Dict(:svc => "events/get",
:params => Dict(
:selector => Dict(
:type => "*",
:timeFrom => start,
:timeTo => stop,
end
items2load = JSON3.write(items2load) |> HTTP.escapeuri
svc = "[url]https://hst-api.telepuls.ru/wialon/ajax.html?svc=core/batch[/url]"
url = svc * "¶ms=$items2load" * "&sid=$sid"
response = HTTP.post(url)
payload = JSON3.read(response.body)
end
If call the function with the first two units like so
events = batch_events(plates[1:2]; week=43, year=2023)
It seems to be loading the events into session. But I'm not getting the actual data, although I've intercalated
:svc:{"events/get"}
requests.
In the image attached you can see a JSON crack image of the data I get
