Jose Donoso wrote:error 7: reason "OPERATION_NOT_ALLOWED: for 'create' operation you should be authorized"
Currently all API requests require sid parameter with session id. Also, "userId" parameter accepts id, not name.
I wrote full example on js (nodejs) to illustrate which requests you need to do:
const https = require('https');
const TOKEN =
'XXXX6c5XXXX8272XXXX894a47376c1e8F2XXXX2C4XXXXAF08B231D2D60XXXX2CC4F8XXXX';
const API_URL = 'https://hst-api.telepuls.ru/wialon/ajax.html';
const FOR_USER = 'another';
main().catch((error) => {
console.error('[main error]', error);
async function main() {
Login with our super-token to create session for other requests
let loginResult = await apiRequest({
svc: 'token/login',
params: {
token: TOKEN,
operateAs: '',
fl: 0,
let { eid: sid, au: userName } = loginResult;
console.log(`Authorized as ${userName}`);
Search user by name
let searchItemsResult = await apiRequest({
sid,
svc: 'core/search_items',
params: {
spec: {
itemsType: 'user',
propName: 'sys_name',
propValueMask: FOR_USER,
sortType: '',
propType: '',
or_logic: false,
force: 1,
flags: 1,
to: 1,
if (searchItemsResult.items.length !== 1) {
throw new Error(`Found ${searchItemsResult.items.length} users`);
let { id: userId, nm: foundUserName } = searchItemsResult.items[0];
Create token for found user
let createTokenResult = await apiRequest({
sid,
svc: 'token/update',
params: {
callMode: 'create',
userId,
app: 'Forum example',
at: 0,
dur: 300,
fl: 2,
p: '{}',
console.log(
`Token for user "${foundUserName}" (id${userId}) created: ${createTokenResult.h}`,
Logout to cleanup session
await apiRequest({
sid,
svc: 'core/logout',
params: {},
Function that does API-call
function apiRequest({ svc, params, sid }) {
return new Promise((resolve, reject) => {
let req = https.request(
`${API_URL}?svc=${encodeURIComponent(svc)}`,
method: 'POST',
headers: {
'content-type': 'application/x-www-form-urlencoded',
(res) => {
let buffers = [];
let totalLength = 0;
res.on('error', reject);
res.on('data', (data) => {
buffers.push(data);
totalLength += data.length;
res.on('end', () => {
let result;
try {
result = JSON.parse(
Buffer.concat(buffers, totalLength),
} catch (error) {
reject(error);
return;
if (!result) {
reject(new Error('no data'));
return;
if (result.error) {
reject(result);
return;
resolve(result);
req.on('error', reject);
let bodyParams = [];
if (sid) {
bodyParams.push(['sid', encodeURIComponent(sid)]);
bodyParams.push(['params', encodeURIComponent(JSON.stringify(params))]);
req.end(bodyParams.map((x) => x.join('=')).join('&'));
