Regarding monitoring 'information accuracy' icons & info
Topic: Regarding monitoring 'information accuracy' icons & info
Hi,
Please check the below issues at http://gurtam.com/en/docs/user-guide/monitoring:icons.
I prefer...
- Number of locked satellites should be shown.
- Current setting (5 min) is fine. Better update the user guide.
Re: Regarding monitoring 'information accuracy' icons & info
User Guide has been updated.
Thank you for your interest and vigilance.
User Guide updated... fine; but still CANNOT see the precise number of satellites locked in the tooltip. Only showing "Satellites successfully locked"; not showing number of locked satellites.
Also consider correcting the spelling mistake in tooltip "Satellites not avaible".  smile
Maruf, your device probably do not sending number of satellites. If device sending this parameter and server parses it it will be visible in popup window.
