451
AT65i
Re: AT65i
Где можно узнать за что отвечает каждая из команд?
gps
        track           clrtrack        ctrltrack
        conf            stat            nums
        vnums           imei            addnum
        shconf          shcnt           shvar
        shdata          shnum           shlog
        save            firstlog        nextlog
        getlogpos       getlogentry     clearfast
        con2gsm         con2gps         con2gls
        con2coord       con2dbg         con2com
        con21wire       ibutreq         con2cx
        setcurr         reboot          shinfo
        shpoly          shtimes         addpoly
        finpoly         addcirc         clrpoly
        poly            setup           guard
        init            masksend        ms
        masklog         ml              gpspwr
        echo            rele            diag
        type            pmsave          master
        clrlog          num             serial
        pass            simpin          gpscom
        limtim          limday          limmon
        diff            sattime         sentime
        log             sen             speed
        voicext         voice           vnum
        vol             vecho           ring
        rvol            vtone           stoptime
        datatime        guardconf       smsconf
        autosendlog     mainservind     timezone
        message         command         extphone
        guardtimehole   guardalarmperiod        guardautoonperiod
        guardblock      guardcall       rdsmsrepconst
        pccount         setdbgdelta     gprsip
        gprsport        gprsphone       gprsapn
        gprsuser        gprspwd         gprsstatus
        gprsconfig      gprsrmgconfig   otherconf
        canconfig       gpspowerrele    sendconfig
        testgps         testtempr       testextd
        testcan         testrom         testdata
        testlog         testcnt         test
        vlsetup         forcefix        extevents
        canloglen       crashloglen     getoper
        loglen          sat_send        sat_init
        sat_get         sat_conf        sat_shconf
        fullsleep       target_ent      targetent
        target_sat201   targetsat201    target_sat_ext
        targetsatext    target_modbus   targetmodbus
        target_modbusext        targetmodbusext target_omni
        targetomni      target_uzi      targetuzi
        target_uzi_c    targetuzic      target_uzi_t
        targetuzit      target_glo_uzi  targetglouzi
        target_com_fms  targetcomfms    target_com_fms_ext
        targetcomfmsext target_com_fms_erf      targetcomfmserf
        target_sapfir   targetsapfir    target_debug_sapfir
        targetdebugsapfir       target_fuel     targetfuel
        target_fuelt    targetfuelt     target_fueltc
        targetfueltc    target_fuelc    targetfuelc
        target_termo    targettermo     target_cat
        targetcat       target_can      targetcan
        target_canex    targetcanex     target_canflm
        targetcanflm    target_taxi     targettaxi
        target_extmodem targetextmodem  target_subc
        targetsubc      target_uss      targetuss
        target_glonass  targetglonass   target_gloext
        targetgloext    target_radio    targetradio
        target_rd_fuel  targetrdfuel    target_radioext
        targetradioext  target_glo_rdext        targetglordext
        target_glo_fuelc        targetglofuelc  target_glo_fuelt
        targetglofuelt  target_can_gls  targetcangls
        target_com_fms_gls      targetcomfmsgls target_ibut
        targetibut      fixgprsip       nofixgprsip
        specuzi         specuzit        specglouzi
        specussdtest    specussd
452
AT65i
Re: AT65i
glonass102 wrote:
cmd> gprsip=193.193.165.165
<$<event NOEVENT (0), val 518, send 0, log 1, 08.05.2015 08:04:16>$>
OK
OK
cmd> write
ERROR:UNKNOWN COMMAND
cmd>
[enter]
save
[enter]
453
AT65i
Re: AT65i
Второй день мучаюсь, не могу увидеть блок на http://id.wialon.net, настроил по инструкции
GPRS ID:9883351680
GPRS DIST:193.193.165.167:20528
GPRS APN:internet.mts.ru:mts:mts
У блока прошивка e4.3g - может из-за этого, может нужна более новая?
Как узнать, соединился ли блок через gprs или нет?
454
AT65i
Re: AT65i
Бывает удобнее посмотреть есть ли хоть какой то GPRS - для этого просто заказываю подробный отчет за текущий день (когда включал блок). Надеюсь СИМка  ваша? и доступ к кабинету есть? Если данные идут, тогда уже разбираться куда, и почему их нет там где искали.
455
AT65i
Re: AT65i
Кто знает почему в виалоне ат65 смотрят всегда вверх (похоже не передают азимут) ?? кто то сталкивался?? как лечится?
456
AT65i
(edited by ElectroZheka 15/06/2015 00:05:59)
Re: AT65i
Всем, Доброго дня.
Обращаюсь к Вам за помощью, можно сказать крик души.
Давно уже попал в руки снятый с авто трекер AT65i (GPRS) Версия 8.1а, но так как протокол на тот момент ещё не разогнули, так и лежал на полке. Вчера вспомнил про него, нашел на gps-trace что трекер стал поддерживаться, решил поставить на личное авто. Всё настроил, заработало, на карте отображалось, разве что не было никаких данных о датчиках(возможно и сервис не поддерживает). Загуглил, натолкнулся на эту тему, попалось сообщение о последней прошивке, ну и чёрт меня дёрнул его штопнуть. Вообщем, не взлетело. Прошиться то прошилось, ток больше на сервисе не отображается. Шил по инструкции, init и серийник вводил. После перепробовал штук 5 прошивок из этой темы, либо модем ресетится, либо gps модуль не запитывается... Вчера вечером накатил full8_4_4g1.whx, провалялся с полчаса, зафиксился, пошло отображение на сервисе, я уж было обрадовался, лег спать. Взял сегодня зверка на работу думал настройкой займусь, подключил, а координат на сервак больше не поступает, т.е связь то есть, посылки приходят, но без координат. Зверь где находится вроде как знает:
cmd> gps
GPS:lat=54.214205,lon=45.119293333,time=03.06.2015 23:53:20,BAS,sat=9,guard=0,course=8,speed=0,gsm=31,gpsat=9,glsat=0,gpsatv=12,glsatv=0,logpos=11,3557
cmd> shvar
Show LOCAL VARIABLE:
Base position:          03.06.2015 19:53:20 N54G12.852M E045G07.158M
Current position:       04.06.2015 07:52:50 No GPS Fix No GPS Fix
Current speed (km/h):   0
Number of GPS satelits: 9
Accurancy (DOP):        1
Vector (grad):          8
Log ptr:                11
Log len:                0
Odometr (km):           0
Motor (sec):    0
GSM network:            MegaFon
GSM signal level:       31
GSM error rate:         0
Diag:           1
GPS echo:       off
Buff pos:       0
Rele stat:      00
GPS power:      on
SMS 8 hour counter:     1
SMS month counter:      1
SMS 8 hour counter notify:      0
SMS month counter notify:       0
Password:       aaa
Module GMT time:        04.06.2015 07:52:54
Time zone:       3
Is DayLight Saving:      1
Module Local time:      04.06.2015 11:52:54
OK
cmd>
Я так понимаю исходя из прочитанного здесь, зверёк залочился((.
Вообщем незнаю что уже делать. ПОМОГИТЕ!
Может есть у кого оригинальная прошивка 8.1a. На самой плате надписи ATrackerV8.1a 2007 RNT. GSM: SIM300Z, GPS: A-02 324-01 YK/0608. Имеет ли смысл у РНТ просить? Как здесь писали они вроде не очень дружелюбны, или шанс есть?
Если нужны ещё какие либо данные - выложу.
P.S. Есть ли какая система в именах прошивок, что буквы обозначают?
457
AT65i
Re: AT65i
montazmas wrote:
elis505 wrote:
Сюда постучитесь  third.checkbox@gmail.com   Были богами РНТ, сейчас на вольных хлебах.   Если 500-700 рублей становятся непреодолимой проблемой, то могу только посочувствовать.
Вы не лучше РНТ, все на коммерческой основе ..  Они блоки хоть и блокируют, но разблокируют бесплатно.  Мы уже месяц используем прошивки , прикрепляю ,  блоки   ловят спутники и все отлично.
для ат65 надо задать серийный номер, команда
serial=12345
через СМС или через консоль блока
Вы выложили прошивку 5.2b -она перестала работать... блок не связывается по GPRS(третья галка убирается)... а у вас как, работает?
458
AT65i
Re: AT65i
Люди! у кого нибудь  есть прошивка для десятки pp_at10_d4.3s12 -выложите!
459
AT65i
Re: AT65i
Такой у нас вроде нет. Из подОбных есть pp_at10_d4.3s25, pp_at10_d4.3s29. Такие не надО?
460
AT65i
Re: AT65i
да. Интересуют ранние прошивки для блоков выложите пожалуйста pp_at10_d4.3s25 или более ранние, а  также и для ат65, если есть раньше чем ENT80(12.05.2010) - 4.2b
461
AT65i
Re: AT65i
462
AT65i
Re: AT65i
senist wrote:
А в хексе есть ?
463
AT65i
Re: AT65i
Для ат65 есть версия 3.7 вроде..
464
AT65i
Re: AT65i
3.7 в хексе ?
465
AT65i
(edited by swm 09/06/2015 12:22:00)
Re: AT65i
plyusch wrote:
3.7 в хексе ?
нет вроде, но вот еще нашел антиквариат, хз какаЯ тут, 2007г. похоже
466
AT65i
Re: AT65i
sermel wrote:
plyusch wrote:
3.7 в хексе ?
СПАСИБО за прошивки..
467
AT65i
Re: AT65i
plyusch wrote:
СПАСИБО
Да поЖалуйста.. Вы ж когда-то сами с нами делились ими smile
Если что полезное нароете - может, нам что подСкажете..
Re: AT65i
А в чем отличие прошивок full8_x_x от ENT80 для трекера AT65?
469
AT65i
Re: AT65i
full8 включает в себя базовый сервис. Лучше ее юзать, т.к. иногда бывает старый баз.сервис.
470
AT65i
(edited by ElectroZheka 09/06/2015 16:37:49)
Re: AT65i
А у Вас нет какого нить старого full8? В идеале тот что на 8.1a ставится, но какая там версия прошивки к сожалению не знаю.  В этой теме самая старая это full8_4_4g1.whx. Проработала вечер и залочилась. ENT80(03.12.2007) залил, не полегчало зверьку(.
Метод сброса третьей галки не подскажете?
Мучаюсь со своим трекером, зацепился на сам gps модуль, вижу nmea поток в сторону проца, но трекер координат якобы не видит и на сервер не отправляет, попробовал стереть еепром 24512, слетают все настройки, ввожу настройки заново, но с координатами проблема не решается. Всю еепром забивал единицами, попробую ещё нулями, мож так прокатит... Незнаю чего ещё с ним делать(
P.S. Попробовал еепром нулями зашить - блокировка не снялась. Пробовал на ENT80(03.12.2007)
471
AT65i
Re: AT65i
Аккуратнее со старыми прошивками, там датчики терялись.
472
AT65i
Re: AT65i
sermel wrote:
plyusch wrote:
СПАСИБО
Есть кое какой баг в прошивках для 65 ...отслеживаю закономерность ...есть у вас прошивка фул  (с базовым сервисом) ENT 3.7 ?
473
AT65i
Re: AT65i
plyusch wrote:
sermel wrote:
plyusch wrote:
СПАСИБО
вроде вот
474
AT65i
(edited by plyusch 10/06/2015 14:38:47)
Re: AT65i
Сообщение удалено модератором
Unfortunately, you are not allowed to view this text
Re: AT65i
